December 21, 2009, 12:20 |
mesh problem
thanos
Rep Power: 17 |
I have designed a 2D naca airfoil and it's control volume. When i try to mesh gambit gives me the following warning: Warn: mesh size on face v_face.5 is smaller than the geometric tolerance.For an accurate mess use larger mesh sizes and/or create geometry at a larger scale. What can i do to balance the mesh tolerance with my geometry? thanks in advance |
December 22, 2009, 22:26 |
YH Tan
Rep Power: 17 |
Can u post the picture of ur 3D model / mesh?
I think u can use Boolean to cut out the portion and use finer mesh on the face it said.
Herntan, Add Reputation if I am right |
December 22, 2009, 22:27 |
Anshul Mittal
Rep Power: 17 |
I think you can improve this by redrawing the geometry on a larger scale.
By default tolerance of Gambit is 1e-6. (You can confirm) If you are drawing the geometry in meters, try millimeters. Hope this helps. Anshul |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 05:27 |
[GAMBIT] Problem with mesh. Please Help... | maziboss | ANSYS Meshing & Geometry | 1 | September 28, 2009 03:24 |
mesh generation problem | Ellen | FLUENT | 7 | February 18, 2009 22:20 |
mesh control problem | TUM | CFX | 4 | July 27, 2001 17:17 |
Convergence problem when ustructured mesh is used. | SangJin Ryu | Siemens | 3 | October 5, 2000 21:26 |
