how to solve"stack backtrace generated for process id 22151 on signal 1:.."? |
December 15, 2009, 12:22 |
stb
Rep Power: 17 |
error happened when i run fluent on workstation based on LINUX version. the detail are showed as follow:
stack backtrace generated for process id 22151 on signal 1: /usr/local/ Fluent.Inc/fluent6.3.26/lnamd64/2ddp/fluent.6.3.26 prease include this information with any bug report you file on this issue. ................................. but it is all right when on XP version. what wrong with it? what causes this problem? how to solve it? it distorts me for a long time. any suggestion are great grateful. and thank you so much. |
February 12, 2011, 21:49 |
I met the same problem as you
duyu
Rep Power: 15 |
I met the same problem as you. Have you ever sloved it? Can you share it with me? I would appreciate it very much.
March 4, 2011, 03:55 |
Stack trace error Fluent
hi all
I am also having the same problem of stack error. I am attaching image file of that. Please suggest a solution for this. |
June 6, 2013, 23:59 |
Anonymous
Rep Power: 13 |
Did anyone manage to solve this problem?? I'm currently facing this problem. The UDF worked perfectly on a Windows machine. But there is a stack backtrace error when I run on a Linux machine
June 7, 2013, 05:56 |
Jim Knopf
Rep Power: 16 |
If you post your error message maybe someone can help.
In general, you have to recompile your udf, make sure that you run in the same mode (serial, parallel), assure that you use the same version of fluent ... Greetz Jim |
June 9, 2013, 01:07 |
Traceback
I think the C++ libraries are not properly installed. First downlad all the libraries like libstdc++ and then run ur udf initially with serial solver.
