Problem with function Compute_Force_And_Moment
Old   December 12, 2009, 17:23
Default Problem with function Compute_Force_And_Moment
Evaldas
zedas is on a distinguished road
Hi, Im not very good in english, but I will try to explain my problem.
My work problem is aeroelastic instability in bridge deck which modeled in 2D. Im wrote UDF wich include function Compute_Force_And_Moment. So, problem is that, this function in my udf return same force value like from return>forces in fluent, but moment value from this function is very very lower than report (moment from udf isnt realistic). Center of gravity I set center of profile. Maybe someone had same broblem or know how this function works? Is there another way to get moment of proflie in UDF? Any advise is welcome.
First part of my UDF.
include"udf.h"
#include"f_wall.h"
#include"dynamesh_tools.h"
static real v_y=0.0,omega_z=0.0;
real dy,da;
DEFINE_CG_MOTION(profilis,dt,vel,omega,time,dtime)
face_t f;
cell_t c;
real f_glob[ND_ND],m_glob[2],x_cg[ND_ND],theta[ND_ND],dv_y,domega_z;
Domain *domain=Get_Domain(1);
Thread *tf1=Lookup_Thread(domain, 6);
int i;
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
for(i=0;i<=ND_ND;i++)
f_glob[i]=0.0;
m_glob[i]=0.0;
for(i=0;i<ND_ND;i++)
x_cg[i]=DT_CG(dt)[i];
theta[i]=DT_THETA(dt)[i];
Compute_Force_And_Moment (domain, tf1, x_cg, f_glob, m_glob, TRUE);
Message (
"\ntime=%f ,x=%.1f ,y=%.10lf ,theta=%.10lf ,force_y=%.5f ,moment_z=%.10lf ,Vy=%.10lf ,omega_z=%.10lf ,moment_x=%.10lf, moment_y=%.10lf\n",time ,x_cg[0] ,x_cg[1] ,theta[2] ,f_glob[1] ,m_glob[2] ,v_y ,omega_z ,m_glob[0] ,m_glob[1]);
zedas is offline   Reply With Quote
Old   October 15, 2012, 01:36
Dorit is on a distinguished road
Hello zedas,
I know it's a long time ago that you sent your post but did you find a solution to your problem? I'm having a very similar problem. My Compute_Force_And_Moment doesn't work.
Thanks,
Dorit
Dorit is offline   Reply With Quote
Problem with compiling my boundary conditions peita OpenFOAM Running, Solving & CFD 5 October 6, 2015 10:16
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
LiencubiclowRemodel nzy102 OpenFOAM Bugs 14 January 10, 2012 09:53
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 11:48
