I need help about User-Defined Fan Model
Old   December 8, 2009, 01:50
Default I need help about User-Defined Fan Model
gy liang
gyliang is on a distinguished road
In FLUENT 6.3 User's Guide7. Boundary Conditions7.24 User-Defined Fan Modelthere is an Example of a User-Defined Fan.
It said that:“ the executable file will be built from the Fortran program, fantest.f, which is shown below. You can obtain a copy of this subroutine and the two that it calls (to read and write profile files) by contacting your Fluent technical support engineer. ”
fantest.f is show bellow:
cc This program is invoked at intervals by FLUENT toc read a profile-format file that contains radiallyc averaged data at a fan face, compute new pressure-jumpc and swirl-velocity components, and write a new profilec file that will subsequently be read by FLUENT toc update the fan conditions.cc Usage: fantest < input_profile > output_profilec integer npmax parameter (npmax = 900) integer inp ! input: number of profile points integer iptype ! input: profile type (0=radial, 1=point) real ir(npmax) ! input: radial positions real ip(npmax) ! input: pressure real idp(npmax) ! input: pressure-jump real iva(npmax) ! input: axial velocity real ivr(npmax) ! input: radial velocity real ivt(npmax) ! input: tangential velocity character*80 zoneid integer rfanprof ! function to read a profile file integer statusc status = rfanprof(npmax,zoneid,iptype, $ inp,ir,ip,idp,iva,ivr,ivt) if (status.ne.0) then write(*,*) 'error reading input profile file' else do 10 i = 1, inp idp(i) = 200.0 - 10.0*iva(i) ivt(i) = 20.0*ir(i) ivr(i) = 0.0 10 continue call wfanprof(6,zoneid,iptype,inp,ir,idp,ivr,ivt) endif stop end Now I am at a loss about
status = rfanprof(npmax,zoneid,iptype, $ inp,ir,ip,idp,iva,ivr,ivt)and wfanprof(6,zoneid,iptype,inp,ir,idp,ivr,ivt)Are they subroutines that need link to fluent or I should write them myself ? Or is there anyone have done similary work and kind to give me some suggestions?
Thanks in advance.
gyliang is offline   Reply With Quote
User Defined Turbulence Model Iaroslav FLUENT 1 July 19, 2017 13:22
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 21:54
how to write user fortran for turbulence model waynezw0618 CFX 2 July 10, 2009 02:55
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 10:19
Model Axial Fan Chien-Chi Chao Siemens 1 February 1, 2001 23:13
