Convergence Problem with body force driven flow
Old   December 7, 2009, 13:15
Default Convergence Problem with body force driven flow
Jinfeng
Jinfeng is on a distinguished road
Hi folks,
I am running a simulation of air flowing through an open-ended channel under the atmosphere condition. The air movement is driven purely by the electrical body force. There is no initial flow at the inlet. It's a laminar steady flow. I tried SIMPLE and SIMPLEC for the pressure-velocity coupling. For pressure discretization, I tried several including Body Force Weighted. I also reduced URF every now and then during the calculation, but none of these trials suceeded in making the calculation converge. Upto a certain point, the calculation will go towards divergence. What should I do with it? Any suggestions would be appreciated!
Regards,
Jinfeng
Jinfeng is offline   Reply With Quote
Old   December 9, 2009, 04:54
Amol Ramteke
Goldsstean is on a distinguished road
If it is not Multiphase flow, then try to intialize you solution with FMG (full multi grid solver). Definitly it will work.
Goldsstean is offline   Reply With Quote
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
Problem in convergence for simulate wind flow around building lalula2 FLUENT 2 June 8, 2009 04:13
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
convergence problem of three phase flow nick CFX 3 April 25, 2008 10:00
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
