sujan dasmahapatra
Rep Power: 0 ![]() |
Dear Friends
I am new to Fluent-Gambit. I am doing the tutorials of mixing elbow where I am creating mesh for mixing elbow pipes. The mesh is created using fluent 4 solver setting. Now I exported the mesh as elbow.GRD but when I am trying to import that file into fluent its not loading the grid giving errors. ///////////////////////////////////////////////////////////////////////////////////// Error: sopeninputfile: unable to open pipe for input Error Object: "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD" Error: Error reading "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD". Error Object: #f Error: %repair-face-handedness: invalid grid. Error Object: () Reading "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD"... Error: sopeninputfile: unable to open pipe for input Error Object: "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD" Error: Error reading "| utility fl42seg D:\CFD\Fluent\Projects\ELBOW\ExportedFromGambit\Mi xingElow.GRD". Error Object: #f Error: %repair-face-handedness: invalid grid. Error Object: () //////////////////////////////////////////////////////////////////////////// what am I missing in this. Any help would be appreciated. Thanks sujan |
mach
Rep Power: 17 ![]() |
Hi
If my memory is right I think, the elbow is 2D. Then while exporting mesh , be sure to select the 2D option button. Regards |
Try exporting the design as a MSH format rather than GRD, and check the "export as 2D" box.
hassan
Q1 Any one do for me mesh file (mesh or dbs I want to calculate surface Nusselt number in for downstream ( near the wall )in expansion pipe with turbulent fluid flow the dimension
Small pipe UN heated Diameter 0.0254 m and width 1.2192m Big pipe heated Diameter 0.09525 m and width 1.7145m Q2 in fluent which turbulent model suitable to my case thank you hassanhayawi@gmail.com |
problem with reading my prePDF file into fluent | James Willie | FLUENT | 9 | March 10, 2012 02:51 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
no spacing in gambit fluent 4 grd file | zonexo | FLUENT | 0 | May 19, 2006 11:47 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
