Total Heat Transfer Rate & Total Surface Heat Flux Mismatch
Old   November 24, 2009, 08:01
Default Total Heat Transfer Rate & Total Surface Heat Flux Mismatch
anonymus
icaro is on a distinguished road
Hi all,
This is my first post ever, let's see if I am lucky. I don't understand the mismatch between results from
#1. Flux Reports / Total Heat Transfer Rate and
#2. Surface Integrals / Report type: Integral / Total Surface Heat Flux
applied to a Wall that limites two solid regions. The thermal conditions for this wall and its shadow is coupled. The result in #1 makes sense from a qualitative point of view (-21 and 21 W, respectively wall and shadow) but doesn't for #2 (-13 and 5 [W/m2]*m2), meaning that not all the heat leaving the wall (13W) goes into its shadow (only 5W).
Could anyone give a hand? Thanks.
icaro
icaro is offline   Reply With Quote
heat transfer, wall
surface Heat Transfer Coefficeint sateesh Main CFD Forum 2 December 11, 2009 07:30
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 23:53
mismatch between heat flux value Vaibhav Khane FLUENT 0 November 19, 2007 16:59
surface to surface radiation heat transfer? suresh Siemens 1 July 7, 2006 07:54
total pressure influence on heat transfer fab Main CFD Forum 8 May 19, 2005 10:24
