overpredicted lift and stall angle
Old   November 15, 2009, 10:06
Default overpredicted lift and stall angle
s.k
student123a is on a distinguished road
hi everyone!
im conducting a CFD experiment for my thesis and have some errors in my results.
Im comparing wind tunnel results and Fluent results for a Naca airfoil. In the wind tunnel, the airfoil (infinite test) was stalling at 14 degrees and max Cl 1.5 . however, fluent is over prediciting these values....giving stalling angle of 17 degrees and max cl of 1.9. im preforming the test at low Reynolds numbers (1.5 million)
Is there any reason for the over-predicted values from fluent? i have a very good mesh constructed by an experienced fluent user so i know that is not causing the problem.
(model used: K-E, RNG)
many thanks
student123a is offline   Reply With Quote
Old   November 16, 2009, 13:12
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
Try using LES turbulence model if there is any change.
Often that kind of problem respond to turbulence model issues.
Also, check the turbulence boundary conditions.
Figd84 is offline   Reply With Quote
stall simulation Kevin Lamers FloEFD, FloWorks & FloTHERM 1 January 29, 2009 07:24
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 17:22
Calculation of lift and drag coefficients Prachi CFX 3 August 14, 2007 15:05
Modelling flow over airfoil at near stall angle Kelvin FLUENT 5 June 6, 2007 03:00
static stall atrh Main CFD Forum 1 March 9, 2004 07:07
