November 11, 2009, 10:04 |
how to output file '*.data' in fluent
Adward
Rep Power: 17 |
i am doing something about aeroacoustics with Fluent & Sysnoise
now i want to output file '*.data' and '*.asd' .the first is about geometry mesh and the other is about pressure data in face . in the help of Fluent ,i can use the following orders to output file '*.data' "define-->models-->acoustics-->write-centroid-info" then i can output '.data' file ,but the file is very small ,is about 3k and is not be used in Sysnoise. my aim is that put the '.data' and '.asd' into Sysnoise in order to build volume distributed quadrupoles sources ,is this way right? someone do about this direction? it is so painful to me ! if you can give me a little suggest ,please give me your hand! thanks all of you ! |
fluent data acoustics |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Precision of Fluent output files | doug | Main CFD Forum | 0 | April 15, 2009 12:59 |
resume and run fluent for another timestep via a c | greg | FLUENT | 2 | June 30, 2005 06:01 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
