Tank sloshing in fluent diverging...need help |
November 11, 2009, 08:15 |
lostin
Rep Power: 17 |
I am trying to simulate a sloshing tank problem using vof and 3ddp. To mimic the lateral motion of tank I have defined a udf of source term in motion direction (n my case it is Y dirn) . I have got results for a time period 0.44 and it seems to be okay. When I am trying to run he simulation for higher time period ( 1.33 ,1.25) my continuity residual is diverging after (1.8-2 sec ) simulation. Here are my solver and other settings.
For different time I need to change my Udf time everytime that I am doing.I have attached my udf. Reading "D:\tank\tanknearfirstmodet=1.25\tanknearfirst mode t=1.25.cas"... 61250 hexahedral cells, zone 2, binary. 9450 quadrilateral wall faces, zone 3, binary. 179025 quadrilateral interior faces, zone 5, binary. 66096 nodes, binary. 66096 node flags, binary. Opening library "libudf"... Library "libudf\ntx86\3ddp\libudf.dll" opened cell_y_source Done. Building... grid, materials, interface, domains, mixture phase-1 phase-2 interaction zones, fluid (phase-1) tankwall (phase-1) default-interior (phase-1) fluid (phase-2) tankwall (phase-2) default-interior (phase-2) default-interior tankwall fluid shell conduction zones, Done. FLUENT Version: 3d, dp, pbns, vof, lam, unsteady (3d, double precision, pressure-based, VOF, laminar, unsteady) Release: 6.3.26 Title: Models ------ Model Settings --------------------------------------------------------- Space 3D Time Unsteady, 1st-Order Implicit Viscous Laminar Heat Transfer Disabled Solidification and Melting Disabled Species Transport Disabled Coupled Dispersed Phase Disabled Pollutants Disabled Pollutants Disabled Soot Disabled Boundary Conditions ------------------- Zones name id type -------------------------------- fluid 2 fluid tankwall 3 wall default-interior 5 interior Boundary Conditions fluid Condition Value ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------ Material Name water-liquid Specify source terms? yes Source Terms ((x-momentum) (y-momentum ((profile udf cell_y_source::libudf) (inactive . #f) (constant . 0))) (z-momentum)) Specify fixed values? no Local Coordinate System for Fixed Velocities no Fixed Values ((x-velocity (inactive . #f) (constant . 0) (profile )) (y-velocity (inactive . #f) (constant . 0) (profile )) (z-velocity (inactive . #f) (constant . 0) (profile ))) Motion Type 0 X-Velocity Of Zone (m/s) 0 Y-Velocity Of Zone (m/s) 0 Z-Velocity Of Zone (m/s) 0 Rotation speed (rad/s) 0 X-Origin of Rotation-Axis (m) 0 Y-Origin of Rotation-Axis (m) 0 Z-Origin of Rotation-Axis (m) 0 X-Component of Rotation-Axis 0 Y-Component of Rotation-Axis 0 Z-Component of Rotation-Axis 1 Deactivated Thread no Porous zone? no Porosity 1 tankwall Condition Value ---------------------------------------------------------- Enable shell conduction? no Wall Motion 0 Shear Boundary Condition 0 Define wall motion relative to adjacent cell zone? yes Apply a rotational velocity to this wall? no Velocity Magnitude (m/s) 0 X-Component of Wall Translation 1 Y-Component of Wall Translation 0 Z-Component of Wall Translation 0 Define wall velocity components? no X-Component of Wall Translation (m/s) 0 Y-Component of Wall Translation (m/s) 0 Z-Component of Wall Translation (m/s) 0 Rotation Speed (rad/s) 0 X-Position of Rotation-Axis Origin (m) 0 Y-Position of Rotation-Axis Origin (m) 0 Z-Position of Rotation-Axis Origin (m) 0 X-Component of Rotation-Axis Direction 0 Y-Component of Rotation-Axis Direction 0 Z-Component of Rotation-Axis Direction 1 X-component of shear stress (pascal) 0 Y-component of shear stress (pascal) 0 Z-component of shear stress (pascal) 0 Specularity Coefficient 0 default-interior Condition Value ----------------- Solver Controls --------------- Equations Equation Solved ------------------------ Flow yes Volume Fraction yes Numerics Numeric Enabled --------------------------------------- Absolute Velocity Formulation yes Unsteady Calculation Parameters -------------------------------------------- Time Step (s) 0.0099999998 Max. Iterations Per Time Step 20 Non-Iterative Solver Factors Variable Max. Corrections Correction Tolerance Residual Tolerance Relaxation Factor -------------------------------------------------------------------------------------------------- Pressure 10 0.25 9.9999997e-05 1 Momentum 5 0.050000001 9.9999997e-05 1 Volume Fraction 5 0.050000001 9.9999997e-05 1 Linear Solver Solver Termination Residual Reduction Variable Type Criterion Tolerance ------------------------------------------------------------- Pressure F-Cycle 0.1 X-Momentum Flexible 0.1 0.69999999 Y-Momentum Flexible 0.1 0.69999999 Z-Momentum Flexible 0.1 0.69999999 Volume Fraction Flexible 0.1 0.69999999 Pressure-Velocity Coupling Parameter Value ---------------------------- Type PISO Neighbour Correction 1 Discretization Scheme Variable Scheme ------------------------------------- Pressure PRESTO! Momentum Second Order Upwind Volume Fraction Second Order Upwind [/B] Solution Limits Quantity Limit --------------------------------- Minimum Absolute Pressure 1 Maximum Absolute Pressure 5e+10 Minimum Temperature 1 Maximum Temperature 5000 Please someone check my solver settings and suggest about it. I am not sure these solver setting are right for simulating sloshing prob.I am just a novice in CFD. thanks for help in advance. Prob;em specification tank size 35X50X40 cm. for time step I have tried 0.001, 0.005 and for all time step solution diverges after specific time. |
November 16, 2009, 13:01 |
Felipe Gutiérrez Donoso
Rep Power: 17 |
You need to write an UDF to that kind of movement. Post it here and I´ll take a look.
November 17, 2009, 03:36 |
lostin
Rep Power: 17 |
Here is my UDF.. I have checked this for som,e cases.. it is diverging nera the resonance freq of the tank...
I think the solver parameters need to change.. #include "udf.h" #define pie 3.141592654 DEFINE_SOURCE(cell_y_source, cell, thread, dS, eqn) { real source; float time = 1.25; /* source term */ source =(-.02)*pow((2*pie/time),2)*C_R(cell,thread)*sin((2*pie/time)*CURRENT_TIME); /* derivative of source term w.r.t. y-velocity. */ dS[eqn] = 0.; return source; } |
February 24, 2010, 08:18 |
Masoud
Rep Power: 16 |
I need source of 2D half fluid modeling in cylindrical tank to calculate fluid frequency provided in Fluent.
February 24, 2010, 08:20 |
Masoud
Rep Power: 16 |
Thanks Mse255@yahoo.com |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 7, 2018 00:37 |
solving ocean wave with Fluent or CFX? | gholamghar | Main CFD Forum | 1 | March 21, 2009 13:49 |
Sloshing Boundary Conditions in Fluent | Prabodh | FLUENT | 0 | April 16, 2006 06:52 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
