Fluent Parallel Programing using Windows HPC 2008
Like Tree1Likes
Old   November 9, 2009, 01:55
Arrow Fluent Parallel Programing using Windows HPC 2008
Santosh
santoshgoku is on a distinguished road
Hii,
I am building a 4 node compute cluster for running Fluent using the Windows HPC 2008 software. I am absolutely new to this and had few questions.
1. In the Fluent Launcher, it asks for the Machine List. What is the format of that?
2. I have created a head node, and a compute node (checking for 2 nodes now). When I start Fluent Launcher and input the parameters and try Launching it, no connection takes place. It does show that it is receiving data from the other computer in the Networking box, but it is not getting reflected in Fluent.
Please help me with this, I will come up with more questions once these steps are clear.
Thanks a lot
Santosh
santoshgoku is offline   Reply With Quote
Old   November 11, 2009, 10:20
Adward
Jame is on a distinguished road
first you must sure that these computers can visit each other in network neiborhood
Jame is offline   Reply With Quote
Old   November 12, 2009, 04:35
tomtom@MS
tomtomdub is on a distinguished road
Have you looked at the Fluent guide for HPCS 2008 ?
"Configuring and Launching FLUENT 12.0.16 on Microsoft HPC 2008" http://www.fluentusers.com/support/i...nfaq/hpc12.htm
Did you tryed to passed the diagnostics from HPC Server ?
By the way, with the fluent launcher you shouldn't have to give him a node list, the HPCS scheduler will provide that to Fluent.
Best regards, Tom
tomtomdub is offline   Reply With Quote
Old   November 13, 2009, 08:51
Santosh
No, I do not have that. My institute did not allow access to that website, maybe I will ask them.
If you have a copy, could you please send me.
Thanks a lot
Old   November 18, 2009, 07:03
Santosh
Bump.. Please help.
Old   December 9, 2009, 14:20
Santosh
Please help.
Originally Posted by santoshgoku View Post
Hii,
Thanks a lot
Santosh
Old   February 25, 2010, 10:36
Default Ansys
Basharat
elbasharat is on a distinguished road
Hey... tell me your problem again. i think I can resolve it....
Martin ))
elbasharat is offline   Reply With Quote
Old   February 25, 2010, 10:42
Santosh
Thanks for posting Martin. But I could solve it. Now set up a 4 node private cluster for Fluent simulations..
Old   February 25, 2010, 14:59
Basharat
ok Good ))... Good luck man. I have worked on linux and windows both of them.
Old   February 25, 2010, 15:10
Santosh
Martin,
I had one doubt though. I had to install Fluent on all the 4 nodes, as the MPICH2 package was needed. Is there any other way to do that without installing Fluent in all the machines?
Thank you.
Old   February 25, 2010, 15:14
Basharat
Dear !
as MPICH2 (Message passing interface)is the best network protocol or software like for good communication and maximum processor performance as well as memory.
tell me in detail you need to install mpich2 or what else you want?
Old   February 25, 2010, 15:20
Santosh
Martin,
Sorry, you didn't get my question.
In order to run Fluent in parallel, I am using mpich2 as the MPI Architecture.
Now, the Fluent in installed on my Head Node, and all the compute nodes are connected to the Head Node.
Now I am running Parallel-Fluent using the Fluent Launcher. While Launching, it gives an error, MPICH2 not found on the compute nodes.
Hence, I install Fluent in each one of them, and run it again, and now it works.
So, my question is, is it possible to run Parallel -Fluent without installing Fluent in all the compute nodes? If yes, then where can I find the MPICH2 package for the particular Fluent version.
Thank you
Old   February 25, 2010, 15:29
Basharat
yeah. you can!
share the head node fluent folder and check if it is accessing from all nodes. then in this share folder of fluent find the multiport folder and see there mpi folder. there is a file of smpd and other files also, copy all files in your system32 or syswow64 (in case of 64 bit) folder.
go to command line and install smpd service by typing
smpd -install
you have to install this service in all your nodes and there is also a file of cluster manager where you can see all your nodes and head node are online highlighted by green line. so
have you got it?
Old   February 25, 2010, 15:32
Santosh
Wow, thanks a lot. Got it perfectly well. I had installed smpd in all the other systems manually after Fluent installation. This idea din't strike me earlier.
Thanks again..
Old   February 25, 2010, 15:37
Basharat
ook... good luck friend. tell you have you ever worked on ansys 12 whether on linux or windows HPC ?
Old   February 25, 2010, 15:38
Santosh
No never. I am working on Fluent 6.3 version.
Old   August 14, 2010, 08:47
Default parallel fluent
  #17
lalit kumar is on a distinguished road
Hi all,
Can any one tell me how to run parallel fluent on 16 processors 2 node cluster using mpi command. I have 8 processors on each node.
thanks frnds
lalit kumar is offline   Reply With Quote
Old   August 14, 2010, 09:13
Basharat
first tell me your scenario ...
I mean.. which version of Ansys you are using and what you want to do exactly ?
Rgds
Martin
Old   May 23, 2011, 04:37
Mohammad
m2montazari is on a distinguished road
hi all,
I had a question which I cant find any answer in fluent userguide or other helps.
I want to have fluent in parallel mode on some nodes(and each node has some cpu cores) but nodes dont have same operating system. some of them have linux amd64 and some have win64. I dont know if I can spawn nodes or not; and if I can, how should be the machine list; should linux systems and windows systems have same username and password to do that or not?
thsnks for any help
m2montazari is offline   Reply With Quote
Old   February 16, 2013, 18:54
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Hi Martin,
I am running Fluent 14 on 2 nodes using Windows 7. I first did a network of these 2 computers; then I set up Fluent and Intel MPI. The Fluent directory is shared in the network as the working directory of Fluent.
I am launching Fluent with 8 processes and it does not hangs when opening. Now it is iterating for the solution but it's taking too long between iterations. I mean, it's kind of pausing after each iteration and it'll take too long to reach convergence if I don't improve this issue. I assume this is due the communication between pcs is delayed or there is a kind of bottleneck in the network. I am please asking you for an advice in this.
Thanks in advance,
César
cesarcg is offline   Reply With Quote
machine list, parallel computing, windows hpc 2008
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
CFX in Windows HPC 2008 Srikanth CFX 5 February 15, 2010 04:42
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Any Luck with 64-bit FLUENT on 64-bit Windows? Dylan FLUENT 4 October 17, 2007 12:14
Windows vistar v.s. Fluent Parallel? Susan YU FLUENT 3 August 16, 2007 00:58
