Fluent Parallel Programing using Windows HPC 2008
Like Tree1Likes
Old   February 16, 2013, 23:43
Basharat
elbasharat is on a distinguished road
Hello César,
It seems like you are running heavy simulation. I have noticed one thing that you are doing pretty well with intel MPI or
as a suggestion use MPICH or MPICH2 then see the difference. You can try this on Linux as well and see if there is any change.
Thanks,
Martin
cesarcg likes this.
Rgds
Martin
elbasharat is offline   Reply With Quote
Old   February 17, 2013, 18:06
Cesar
cesarcg is on a distinguished road
Send a message via Skype™ to cesarcg
Oh, right! It would be good to try these 2 options out, but I may have to do it via command line since in the GUI launcher of Fluent 14 are not available, at least in the version I'm running. I'd like to try this in Linux but now it's urgent to obtain results for my thesis. Maybe later when I have more free time.
Regards
cesarcg is offline   Reply With Quote
Old   February 23, 2013, 01:56
Cesar
Hi Martin,
Hope you are doing well. I'm facing a problem now trying to add another CPU to the ones I told you before in the past thread. This new machine has Windows XP - 64bit as OS. As I told you I have 3 machines with Windows 7 running Fluent in parallel. The MPI for these 3 machines is Intel. I followed the steps to set the MPICH2 as you suggested in the next quoted message:
Originally Posted by elbasharat View Post
share the head node fluent folder and check if it is accessing from all nodes. then in this share folder of fluent find the multiport folder and see there mpi folder. there is a file of smpd and other files also, copy all files in your system32 or syswow64 (in case of 64 bit) folder.
go to command line and install smpd service by typing
smpd -install
you have to install this service in all your nodes and there is also a file of cluster manager where you can see all your nodes and head node are online highlighted by green line.
But I couln't make it work. I made sure that every machine can see the other ones in the network. There is no problem in copying and moving files between them, too. When I try to run Fluent using this new machine as a new node with Windows XP, it hangs printing a message that reads something about a port 8677 and that the connection could not be done. I assume that this is due the XP OS of the new CPU but I think that this should not be a big deal since all are 64-bit operating systems.
Now I'm back again with the 3 machines I had before while I fix this problem. Please, give me an advice. I'm sure this can be solved.
Thanks in advance,
César
machine list, parallel computing, windows hpc 2008
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
CFX in Windows HPC 2008 Srikanth CFX 5 February 15, 2010 04:42
Fluent parallel license problem brothershuai Main CFD Forum 0 July 1, 2009 16:41
Any Luck with 64-bit FLUENT on 64-bit Windows? Dylan FLUENT 4 October 17, 2007 12:14
Windows vistar v.s. Fluent Parallel? Susan YU FLUENT 3 August 16, 2007 00:58
