error for loading UDF
Old   November 5, 2009, 14:47
Default error for loading UDF
ibuki kusano
ibuki is on a distinguished road
Hello. I'm new to UDF and doing one of the tutorials. I have .c file in the working directory, and when I try to load the library after building it , I get a following error message: Opening library "libudf-check"...
Error: open_udf_library: the system cannot find the specified file.
Do I need more files in the directory besides .c?
Thank you.
ibuki is offline   Reply With Quote
Old   November 6, 2009, 02:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
your source file should be on the same folder as your case file
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   November 6, 2009, 15:08
Default c compiler
anonymos
erkut is on a distinguished road
you may not properly compile your c code.
Be sure c compiler is installed on your computer and you set up environmental variables correctly.
erkut is offline   Reply With Quote
Old   November 7, 2009, 05:11
jsm
JSM
jsm is on a distinguished road
you can find lot of threads with complete solution for UDF compiling problem. Just search in this forum. Also step by step procedure is available in fluent customer portal with possible errors & resolutions.
With regards,
JSM
jsm is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
