MRF & gravity
Old   October 31, 2009, 02:36
Exclamation MRF & gravity
Shu-xin Cui
xinboy is on a distinguished road
Hello, everyone!
I'm simulating a rotary dryer using 2-D model (x-y plane) and intend to use MRF.
The dryer is rotating around the horizontal axis (z-axis) and contains a lots of spoilers that is close to the outer wall. There are water and vapor inside the dryer and VOF model is used. The gravity should be considered.
I have used MRF and aligned the gravity with -y axis (by opening the operation condition). But the result is not true. (the water anywhere seems to be attracted by the force that is -y direction)
I think the gravity item in N-S equation at rotating frame should be varied with time, while FLUENT assumes that it is constant. So it will be resolved by UDF.
Could you be agree with me?
Any views you can put?
I would be appreciated .
xinboy is offline   Reply With Quote
gravity, mrf
how to consider gravity in CFX shrimp CFX 4 September 8, 2008 21:41
Gravity in STAR-CD Sachin Patil Siemens 10 January 31, 2008 23:13
variation of gravity with time rajani FLUENT 0 February 16, 2005 03:45
Help: gravity in CFX Dejun Jing CFX 2 July 22, 2002 09:58
On gravity modelling... Drona CFX 7 November 22, 2001 11:28
