October 30, 2009, 05:27 |
Pb in conv. k-e 3D Help
Mines
Rep Power: 16 |
I am running a 3d simulation using the standard K-E model. after 10 iterations "sliding mesh simulation" (in steady state flow) values of k & epsilon are diverging. I have the message: "Turbulent viscosity limited to viscosity ratio of 1e5 in cells". I used pressure based solver. Can anyone help with this please? Thanks. |
October 30, 2009, 05:28 |
mesh
wayusen
Rep Power: 16 |
pl. check mesh quality.
October 30, 2009, 05:44 |
Mines
Rep Power: 16 |
I do grid--check, everything is good!
October 30, 2009, 06:18 |
Mines
Rep Power: 16 |
and if I make simulation in laminar flow, solution converge!
October 30, 2009, 15:51 |
Tez
Rep Power: 16 |
Try with very small under-relaxation numbers and gradually increase them to default values. That might help.
November 2, 2009, 06:16 |
Mines
Rep Power: 16 |
Hi Tez,
I divided UR factors by 100, results are better . but there are fluctuations of the epsilon parameter. After 100 iterations the residuals of k and e parameters are about 5.e-2. tell me plz. how to increase gradually these parameters? by stopping and restart calculation and increasing URP without initializing? |
November 3, 2009, 06:42 |
hello
reza
Rep Power: 16 |
I think it is better to give a inviscid solution and then set it as a intial condition for turbulent solution.another way is to set the "turbulent insity" and "turbulent viscousity ratio" to 1 at velocity inlet.
November 4, 2009, 05:26 |
Mines
Rep Power: 16 |
Hi greeneye,
I apply your second proposition but k & epsilon residuals remind at too high values (about 1.e-1). I have a simple question for you: how to use a solution as an initial condition in Fluent? by iterating without initilize solution? thanks |
3d simulations, k-epsilon model, sliding mesh |
Problems with the RSM in simpleFoam | sberg | OpenFOAM Running, Solving & CFD | 10 | February 25, 2014 19:39 |
[Commercial meshers] Converting Gambit Neutral Meshes | plmauk | OpenFOAM Meshing & Mesh Conversion | 2 | July 20, 2007 07:08 |
FvVectorMatrixresidual before solving | cosimobianchini | OpenFOAM Running, Solving & CFD | 0 | January 28, 2007 11:02 |
[Gmsh] Gmsh with physicals | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 9 | February 2, 2006 14:36 |
conv variable in cfx4.4 | Tad | CFX | 1 | March 12, 2005 11:42 |
