Importing previous results as a starting point for future simulations
Old   October 28, 2009, 19:22
Default Importing previous results as a starting point for future simulations
Jamie
mcintoshjamie is on a distinguished road
I'm conducting a research project for my Masters degree to do with profiled endwall design for a linear cascade. The project uses a genetic algorithm that creates perturbations across the end wall and then sends these designs to be meshed in gambit and then analysed in fluent.
Currently the system takes 2.5 hours per design with 30 simulations per generation. I'm trying to optimise the system so that the calculation time is decreased using parallel processing on a myrinet system and also by using a 'surrogate model'.
Essentially what I'm trying to do is use a planar end wall simulation as the starting point for calculations on each new design as the hope is that this will significantly reduce the number of iterations required to converge on a solution.
I've had a look on the internet and the help files in fluent and couldn't find anything specific about this. I would have thought it's possible but can't think of a way to make it happen. Any help is appreciated.
Thanks
Jamie McIntosh
mcintoshjamie is offline   Reply With Quote
Old   November 15, 2009, 07:38
Jamie
Solved:
1. File-->Read-->Case (as normal)
2. File-->Interpolate*
3. Read...
Iterate towards solution as before...
*Requires interpolate data file from previous results:
1. File-->Interpolate
2. Write...
Jamie
import previous, previous results, speed up, surrogate model, use previous
Using results form previous run as inlet condition lauren CFX 3 June 9, 2008 14:32
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
Exporting Fluent results and importing into StarCD Jim Loebig FLUENT 0 July 20, 2007 17:26
bad results when compared with other simulations Le Stanc CFX 12 November 8, 2006 02:47
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
