modeling of volume inside volume in gambit
Old   October 21, 2009, 08:21
Question modeling of volume inside volume in gambit
rahul
rahulsharma is on a distinguished road
hey everyone
I want to model a volume inside a volume and than how will i get final model so that flow of fluid should be affected by both inner and outer volume.
So please suggest me which command will be best for separating these volumes....
rahulsharma is offline   Reply With Quote
Old   October 21, 2009, 08:28
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Generate the two volumes, substract one from the other then mesh the resulting geometry
Philipov is offline   Reply With Quote
Old   October 22, 2009, 09:14
JP
srjp is on a distinguished road
I assume you want to model the flow inside volume-1 and around the inner volume-2, like flow inside a tube, with an obstruction.
If that is the case, yes, you can subtract vol-2 from vol-1 since flow happens only in the remaining space. In this case you can delete vol-2.
If flow occurs in both volumes, you need to mesh both volumes, and then define them as different zones in gambit.
srjp is offline   Reply With Quote
Old   October 23, 2009, 09:19
rahul
thanks srjp
i will do this than inform you what will be the situation.
question on generating sliding mesh in Gambit multiphase-flow FLUENT 4 February 21, 2012 01:36
[blockMesh] Solid volume inside computational domain francois OpenFOAM Meshing & Mesh Conversion 7 November 19, 2008 17:11
How to create a fluid volume inside a solid volume sanin FLUENT 4 November 13, 2008 16:17
Parametric Modeling with GAMBIT David Shkval FLUENT 4 March 7, 2002 08:50
