Boussinesq Assumption
Old   October 19, 2009, 13:50
Default Boussinesq Assumption
tstorm is on a distinguished road
Hi all,
I've read that the Boussinesq assumption linearized the relationship between the turbulent stresses and the mean strain rate, so:
u_i*u_j=2/3*k*del_ij - 2*nu_t*S_ij
I've also seen people say that the Boussinesq assumption makes the normal stresses isotropic, so:
uu=vv=ww=2/3*k
My question is where does the second term go? Does the Boussinesq assumption also assume that du/dx = dv/dy = dw/dz = 0?
Thanks!
tstorm is offline   Reply With Quote
Old   October 22, 2009, 09:57
JP
srjp is on a distinguished road
When the normal stresses are made isotropic, the first term vanishes and you have the linearized equation for the turbulent shear stress (second term)
as:
tau_xy = mu_t * du/dy
where mu_t is the turbulent viscosity
srjp is offline   Reply With Quote
Old   October 22, 2009, 11:12
Thanks, but why does the first term vanish? It should vanish if the Kronecker delta is zero, which happens for the off-diagonal terms, not the diagonal terms.
I'm clearly still confused. I appreciate your help!
Old   October 26, 2009, 06:11
Krishna
t.krishnamohan is on a distinguished road
Expression for Tou ij =2*mue_t*Sij-2/3*k*rho*del_ij;
Sij=2(dui/dxj+duj/dxi)----------Terms here are time averaged.
When i=j; Sii=0 for incompressible flows.
Recollect the time averaged continuity equation.
t.krishnamohan is offline   Reply With Quote
Natural Convection in a storage tank - boussinesq? Jervds CFX 6 October 2, 2016 03:53
Density boussinesq Problem matrix-1.0 FLUENT 9 January 17, 2014 22:17
Boussinesq lucifer FLUENT 0 September 26, 2009 10:31
Boussinesq - natural convection Jeremie FLUENT 2 March 8, 2007 09:12
GAMBIT: Assumption of an edge type while meshing Agnes FLUENT 0 June 22, 2005 14:37
