User-defined k
Old   October 17, 2009, 13:22
Default User-defined k
gina
gina is on a distinguished road
Dear all,
I want to use UDF to modify the kinetic energy (k) field in the locations where the y plus value is less than 20.
is there anyone who can help me?
thanks
gina is offline   Reply With Quote
Old   October 17, 2009, 19:39
tstorm is on a distinguished road
You can define a new source equation (using DEFINE_SOURCE), and inside that source add an if statement to take care of the y+<20 part. Then you'll hook that source equation to the k equation (DEFINE - BOUNDARY CONDITIONS - FLUID).
I'd be happy to help you along if you have more specific questions.
tstorm is offline   Reply With Quote
Old   October 23, 2009, 15:12
gina
thank you very much to have answer for me...
I have use a udf with define_adjust, is that not correct!
Old   October 23, 2009, 19:05
Yes, you can use an define_adjust as well, there are several ways to approach your problem.
You can use define_adjust to adjust the k value.
Or, you can use define_source to define a NEW k value, and set your new value to FLUENT's k.
Old   October 24, 2009, 17:13
Default define_source
gina
Ok well, please if i need to use define_source and when i will to hook my source equation in DEFINE - BOUNDARY CONDITIONS - FLUID in this panel what I must do?
thanks
Old   October 26, 2009, 08:42
Krishna
t.krishnamohan is on a distinguished road
DEFINE_WALL_FUNCTIONS should be used for specifying user defined wall functions. Hope you are using k-epsilon model to define turbulence. Please go through the online doc for number of arguments for this function.
You cannot use DEFINE_SOURCE/ DEFINE_ADJUST for specifying user defined wall functions.
Regards,
t.krishnamohan is offline   Reply With Quote
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 06:29
UDF - Derivatives for User Defined Memory Variable Sandilya Garimella FLUENT 0 January 14, 2008 11:39
Gradient of a User defined Variable Ramadas CFX 2 August 21, 2007 10:19
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 19:18
Usage of user defined functions Gowrish FLUENT 1 October 26, 2005 08:44
