problem in using MRF model
Old   October 13, 2009, 08:18
Default problem in using MRF model
haamed mohajer
haamed is on a distinguished road
Hi
we are analysing a wind turbine with Fluent, we tested 2 models for rotating turbines(MRF& moving walls for blades). But the results of MRF model is completely out of range while the results of moving wall model is near to desired range.
we will appreciate you if you guide us.
haamed is offline   Reply With Quote
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 06:50
problem of dynamic mesh for a piston model pipin Fluent UDF and Scheme Programming 2 August 2, 2010 15:35
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
Non premixed model - combustion validation problem David FLUENT 2 October 24, 2003 11:06
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 03:55
