FLUENT 64-bit on 64-bit System
Old   October 9, 2009, 14:29
Unhappy FLUENT 64-bit on 64-bit System
fluentfreak
fluentfreak is on a distinguished road
I am experiencing strange things using my upgraded 64-bit Fluent version. I had it installed on a linux machine; but moved it to a win64 machine to make sure it's not the OS fault. But the problem is still there.......now the problem:
3D Turbulent external flow (modeled as if it was in wind tunnel), 2.5 million grid cells, turb model:any, ran on parallel mode to use all 4-cores of the AMD QUAD CORE Processor
BUG: I get errors from AMG solver; the same thing used to run perfect on 32bit machine (parallel Quad Core). It also works well on my 64bit machine when I run as Single processor.
HAS ANYONE EXPERIENCED THE SAME THING?
ANY COMMENTS?
Thanks!!
fluentfreak is offline   Reply With Quote
Old   November 18, 2009, 06:03
Default Amg
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
AMG solver is not the error of an operating system, you may have diveregence some wheare, try to see if your Boundary constiitons are correct.
Shamoon Jamshed is offline   Reply With Quote
Old   November 23, 2009, 05:45
fluentfreak
Thanks for your reply.
I have the same model on a windows machine....everything is the same...all the settings.....the model...grid....
but the one on linux gives me this error message after about 1000timesteps.
I think that's the installation.....but how can I fix it?
Old   September 7, 2010, 14:28
Shamoon Jamshed
Try to reduce under relaxation factor
If it doesnt work then try to run first order with only flow equations solved, then also solve the energy equation and after some stable residuals start second order.
IT should nt be a problem in density based solver. If yes start with a lower courant number.
64bit, amg, fluent, win64
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 19:56
UDF problem with 64 bit operating system? phillerup Main CFD Forum 0 July 23, 2009 14:00
why does not udf source file wor on 64 bit system? Jason K FLUENT 2 January 4, 2009 17:11
fluent 32 bit maximum RAM Mike FLUENT 2 August 19, 2006 10:45
help install fluent in RedHat system arwang FLUENT 8 July 13, 2004 11:07
