Slug Flow in channel
Old   October 1, 2009, 19:24
Post Slug Flow in channel
yasna razavi
yasna is on a distinguished road
Send a message via Skype™ to yasna
Dear All
I am trying to model the Slug Flow in rectangular channel by 2D simulation. The dimentions are length=8000mm and height=100mm. The grid consists of 100000 quadrilateral elements. There is some problem in convergence of continuity equation.
Major properties of model are:
-2d,vof,Standard k-omega,pressure based
-distinct velocity inlet for air and water,pressure outlet for outlet
-equ:flow,volume fraction,turbulence
-pressure velocity coupling=PISO
-descretization Schemeressure-presto,momentum=quick and for other equations=second order
both of phase are incomperssible. Lower 50% of channel is filled by water and upper 50% section is full of water. The enterance velocity of water=2m/s and enterance velocity of air=10m/s.
I know the main reason of problem is intial condition. but unfortunately,I cant find the appropriate IC for this turbulence model.
Any suggestions will be appreciated.
Thanks in advance
yasna is offline   Reply With Quote
Old   October 2, 2009, 10:20
Felipe Gutiérrez Donoso
Figd84 is on a distinguished road
Have you tried with k-epsilon?? to knlow if the problem is the turbulence model.
Figd84 is offline   Reply With Quote
Old   October 2, 2009, 15:21
yasna razavi
Hi figd84
thanks for your suggestion but I tried k-e befor and I have same problem again.
initial condition, k-omega, slugflow
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 22:39
two phase slug flow Justion FLUENT 4 June 5, 2014 11:47
pressure outlet (open channel flow) Willem Brantegem Main CFD Forum 0 April 3, 2007 10:39
open channel flow boundary conditions yan FLUENT 0 July 5, 2005 00:36
The initial condition for turbulence channel flow Ma Jianfeng Main CFD Forum 1 April 20, 2005 04:50
