October 14, 2014, 07:35 |
#21 |
Rep Power: 26 |
*Open Workbench
*Add a geometry, so you can open Designmodeler *Sketch/model the aerofoil in the way you want *Go to the Ansys Mesher *Mesh the geometry with CFD settings *Go to Fluent *and so on Is this the first time that you will use Ansys software? Didn't you follow a tutorial? |
October 14, 2014, 07:40 |
#22 |
Radwanma
Rep Power: 12 |
soory How can I darw an aerofoil by using ansys ? is it ok do understand what I mean ?
October 14, 2014, 07:43 |
hi
#23 |
Radwanma
Rep Power: 12 |
Thanks , I want to is there any easy way to draw the aerofoil without using the designmodel ?
October 14, 2014, 07:45 |
#24 |
Rick
Rep Power: 26 |
Radwamna,
you can draw your airfoil by importing points, creating edges, surfaces and volumes (if 3d). You can draw the model in cad (autocad, solidworks, or what you want...) and importing into your favourite pre-processor software. If you are not able to draw geometry, refer to other forums, related to use of cad softwares. |
October 14, 2014, 08:56 |
#25 |
Rep Power: 26 |
Radwanma,
We can only read what you type. You want to draw an aerofoil using ansys, but then suddenly you don't want to use designmodeler. You should have included that in the question. Please, can you give a detailed question of what you want? Using at least three sentences? You keep repeating that you want to make/draw an aerofoil, but if you want a detailed answer, you should ask a detailed question. |
June 9, 2015, 04:40 |
fluent not showing mesh
#26 |
Vishnu V Chandran
Hi friends,
Lately my ansys fluent 15 is not showing the mesh file that I did in ICEM. Instead it is showing just a white screen in the mesh region. Can anyone give any valid suggestions. |
June 9, 2015, 15:38 |
#27 |
Radwanma
Rep Power: 12 |
Hi All,
Does anyone have an idea how can I do a mesh for 3 blades wind turbine in ICEM ?. I have made the geometry but I have made many mistakes with my mesh !!!! , please ? Regards, |
February 6, 2018, 03:34 |
dear
#28 | |
Payam
you have to turn on "Embed Graphics Windows" when you are opening fluent. |
Problem with 2D ICEM mesh check in fluent | Nicola | FLUENT | 3 | March 25, 2013 05:56 |
ICEM BC to FLUENT | Simon | CFX | 3 | September 9, 2008 17:08 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Exporting ICEM Mesh into Fluent... | Harmeet | FLUENT | 1 | July 28, 2004 02:56 |
