Mixing Station with high swirl
Like Tree1Likes
Old   November 5, 2009, 11:00
Neil
Trev is on a distinguished road
Hi Ale,
Sorry for the late reply but I've been really busy recently.
For the turbulence intensity I would suggest using around 5-10%.
With regards to the target mass flow rate test it to see if the solution remains stable and if not I wouldn't use it.
Neil
Trev is offline   Reply With Quote
Old   November 5, 2009, 11:29
AleDR's Avatar
Alessandro
AleDR is on a distinguished road
Hi Neal!
Thanks for your reply and don't worry... in the meantime I was working on a side project for a swirl burner (...still RSM!)! And I'm trying to get OpenFOAM installed on an idle machine too. I found some interesting posts in the forum and I'd like to have a try... Do you have any experience about it?
As for the pressure outlet b.c. for the mixing station I would like to try a procedure:
1. Turn on the target mass flow rate option for few iterations, in order to have a first value for the pressure at the outlet;
2. Turn off the option and correct the pressure value with the new estimate.
I hope this could help..!
With regards to the turbulence intensity I will use the values you suggested.
Anyway I'll let you know if convergence will be improved!
Bye bye!
Ale
AleDR is offline   Reply With Quote
Old   November 5, 2009, 12:16
Neil
I have some experience with modelling reactive flows in cyclone combustors for which the case setup is similar and I can try and help out but there are bound to be more experienced people on this forum.
Old   November 5, 2009, 12:49
AleDR's Avatar
Alessandro
Cyclone combustors??
But this sounds very similar to the side project I'm working on!! And I guess your experience is much more than what I deserve!
Anyway I'm still trying to complete installation correctly, because I don't have experience with Linux OS! Meanwhile, I'm learning something more about Ubuntu!
But I will share willingly anything about it as far as I get a functioning OpenFOAM on my machine..!
...let's hope!
Now I'm still meshing some alternative designs for testing them on Fluent as usual. After that I will have to select a design for prototyping ad testing at full industrial scale. And then, when I will have some experimental data, I hope to compare Fluent and (hopefully!) OpenFOAM predictions on the same mesh exported from Gambit.
I think it will be really interesting!
So thanks for your support!
convergence, fluent, mixer, model selection, swirl
Cyclone high swirl bramv101 ANSYS 2 July 9, 2009 10:45
Mixing of two different fluids in a swirl AK FLUENT 3 July 11, 2007 08:32
Segregated or Coupled? High Speed Flow Mixing. Mazhar Azim FLUENT 2 March 29, 2007 11:53
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
Swirl in backflow on pressure outlets Jonas Larsson FLUENT 17 February 3, 2000 03:14
