Heat transfer coefficent for the coupled wall |
September 22, 2009, 05:15 |
Rep Power: 17 |
I am trying to simulate a fluid-solid problem. At the interface between the fliud and solid, I want to set a the heat transfer coefficient. But in Fluent, there is no such option if i choose "coupled wall" boundary condition. So I set the wall thickness at the interface in order to get the right value of heat transfer coefficient.
The problem is, how to know that I set the right wall thickness, can I check the heat transfer coefficient in Fluent ? |
September 30, 2009, 11:46 |
Tim Maguire
Rep Power: 17 |
Did you try turning on the thermal model and specifying the heat transfer coefficient for the solid? This way you do not have to specify the thickness of your wall.
October 1, 2009, 04:10 |
Rep Power: 17 |
In my problem, I had two adjacent materials, solid and fluid (like mold and liquid). The solid is not just a wall, it has thickness and I want to simulate its temperature field. So I use the "coupled wall "in Fluent. In such case, I can not specify the heat transfer coefficient for the solid.
October 1, 2009, 04:33 |
you need not set htc. it calculates automaticaly on system of equations (navier-stokes, energy...)
you can check htc in post processor. regards. |
October 1, 2009, 17:38 |
mangal
Rep Power: 17 |
It is basically a conjugate heat transfer problem. Code solves the energy equation for both material (fluid and solid) together. Just make sure that you have good mesh resolution near the wall for correct/accurate heat transfer. Post processing should allow you to look at the heat transfer coefficient. Remember, heat transfer coefficient can be calculated in three different ways.
1. Based on reference temperature 2. Based on adjacent fluid temperature 3. Based on wall function. I believe if you resolve near wall region well, you should be able to get accurate HTC values |
February 24, 2010, 04:12 |
Chua Ang Tze
i would like to know how to get the coupled boundary condition. it is not available under thermal.
also in gambit, i've already set the continuiity type to SOLID and FLUID respectively. but i couldnt get the shadow zone. please enlighten me. thanks in advance |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 17:29 |
Wall Heat Transfer Coefficient | sachinthakre | CFX | 3 | July 14, 2009 23:25 |
Huge Wall Heat Transfer Coefficients with SST Mode | Marco Müller | CFX | 3 | December 19, 2008 08:55 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 19:53 |
Prediction of wall heat transfer coeff. | Sridhar | Main CFD Forum | 0 | August 9, 2002 08:27 |
