Parabolic velocity profile at vertical entrance |
September 20, 2009, 21:29 |
Frank Peng
Hi Guys,
I'm working on a FLUENT question involving a tee-junction. I have one problem which I don't know how to handle. The vertical inlet is 1 m wide and has its velocity has a parabolic profile. This seems to require some sort of User Defined Function as part of the boundary condition. I searched on the Net and found the following C source code which can be compiled into FLUENT: /************************************************** ***********************/ /* udfexample.c */ /* UDF for specifying a steady-state velocity profile boundary condition */ /************************************************** ***********************/ #include "udf.h" DEFINE_PROFILE(inlet_y_velocity, thread, position) { real y[ND_ND]; /* this will hold the position vector */ real x; face_t f; begin_f_loop(f, thread) { F_CENTROID(y,f,thread); x = y[1]; F_PROFILE(f, thread, position) = 20. - y*y/(.0745*.0745)*20; } end_f_loop(f, thread) } However, this code defines a parabolic velocity profile for a horizontal inlet and doesn't quite apply to the question which has a vertical inlet. Could someone help me please? Much appreciated!!! Cheers Last edited by ztp911; September 21, 2009 at 04:28. |
September 21, 2009, 16:26 |
Bernhard
Rep Power: 22 |
F_CENTROID(y,f,thread); x = y[1]; In the next line your code used y, but I assume you want to use your new variable x there. Good luck! |
September 3, 2013, 07:10 |
UDF for inlet profile
Goutam Saha
Rep Power: 15 |
I considered a simple laminar pipe flow problem:
#include "udf.h" DEFINE_PROFILE(inlet_velocity, t, i) { real y[ND_ND]; real x,r; face_t f; r=0.0095; begin_f_loop(f, t) { F_CENTROID(y,f,t); x = y[1]; F_PROFILE(f, t, i) = 0.009022 - 0.009022*((x*x)/(r*r)); } end_f_loop(f, t) } I used this code at inlet but I am always getting uniform velocity at the inlet. Why? When I initialize the solution from inlet, it shows the value 0.009022? I didn't find the error? Any suggessions ????? |
fluent, parabolic, tee-junction, velocity profile, vertical inlet |
3D UDF Paraboilc Velocity Profile (Can't Maintain) | Sing | FLUENT | 12 | August 7, 2017 07:25 |
problem in 3d parabolic velocity profile | Lokesh | FLUENT | 8 | August 11, 2005 06:36 |
How to create a parabolic velocity profile | Nelson | FLUENT | 0 | July 7, 2005 03:49 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
