Unreal vortices in NACA0012 at high angle of attack
Old   September 17, 2009, 01:03
Default Unreal vortices in NACA0012 at high angle of attack
parvez
parvez2683 is on a distinguished road
Hi friends,
I am simulating steady state 2D naca0012 airfoil at high angle of attack. I made the C type grid with 50C*50C dimensions with blunt trailing edge. Everything is good untill when I am trying to simulate it at higher AOA like 16its showing me the vorticity near the two face connections at the trailing edge which seems to be quiet unreal. anybody knows how to fix the problem.
I am attaching the pictures of the airfoil vortices at AOA 16.
http://img32.imageshack.us/img32/3418/62143078.jpg
http://img6.imageshack.us/img6/1402/16041239.jpg
http://img7.imageshack.us/img7/9769/92423939.jpg
http://img6.imageshack.us/img6/3161/15773007.jpg
Case file link:
http://www.4shared.com/file/13324788...rfoil0012.html
parvez2683 is offline   Reply With Quote
Old   September 18, 2009, 13:27
tstorm is on a distinguished road
It looks like the trouble is grid-generated because both of those regions have high aspect-ratio cells. I've seen similar results in some of my cases. Try adapting the grid in those regions, either in FLUENT or your grid generator. FLUENT would probably be better, so you only adapt the cells in question instead of making the entire grid finer.
tstorm is offline   Reply With Quote
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
Fluent-wrong cl value at high angle of attack Lucas FLUENT 8 December 1, 2010 07:18
modelling inviscid 2D flow at high angle of attack Ferdinando FLUENT 2 October 30, 2007 18:26
High Angle of Attack w0er Main CFD Forum 3 March 8, 2005 12:05
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
