September 16, 2009, 09:07 |
Rearward facing step simulations
Stuart
Rep Power: 26 |
I will be running some transonic, viscous simulations on a 2D rearward facing step. I'll run some preliminary simulations to assess solution independence to mesh density, fluid domain size and viscous structured mesh layer height. However, what parameters are recommended to use for these independence assessments? Pressure distribution on the rear face of the step, turbulence parameters on the domain outflow face? Also, any recommendations of domain and mesh sizes for me to use as a start? The step height is about 0.2m and y+ will be in the range of 30, I guess. Also, am I correct in thinking that becuase this is a 2D simulation I cannot use DES and LES turbulence models? Thanks |
September 23, 2009, 03:21 |
Stuart
Rep Power: 26 |
Has nobody modelled such a flow before and can offer help?
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 17, 2019 00:12 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
the reattachment length of rearward facing step | Tom,L. | Main CFD Forum | 4 | December 14, 2002 05:24 |
