September 9, 2009, 05:54 |
Pressure drop match
Praveen Kumar Jagarlapudi
Rep Power: 17 |
Dear all,
I have a question please clarify. I have a problem in matching pressure drops at inlet and outlet in a flow through bend pipe. I have certain pressure drop to match like 200 pascals. But i am getting only 20 pascals pressure drop. I gave velocity inlet and pressure outlet as my B.C's. How can i get the pressre drop of 200 pascals for the given velocity. Its very urgent. Thanks in advance. |
September 10, 2009, 01:47 |
Maxime Perelli
Rep Power: 41 |
is your massflow rate in agreement yith your prediction?
have you check your unit (scale) how did you compute the pressure drop?
In memory of my friend Hervé: CFD engineer & freerider |
September 11, 2009, 03:19 |
Rep Power: 17 |
mass flow rate & volume flow rate matched at inlet & outlet.
Units are taken care. Pressure drop(20 mm of water cloumn) = pressure difference between inlet & outlet. Pressure drop(225 mm of water cloumn) provided by the customer. |
September 11, 2009, 03:36 |
Maxime Perelli
Rep Power: 41 |
how did you proceed to compute the pressure drop within fluent?
You should do followings: *report/surface (area weighted surface with total pressure), choose inlet and note the value *the same with outlet *computing the difference will give you the pressure drop
Pressure Drop in outlet Vent | Abdul | FLUENT | 2 | October 28, 2008 12:13 |
Pressure Drop at entrance of a rotor-stator. | Resnick | Main CFD Forum | 0 | November 20, 2007 14:50 |
pressure drop | siddiqui | FLUENT | 2 | March 15, 2006 06:13 |
specified pressure drop | subhra | Main CFD Forum | 0 | May 29, 2005 12:43 |
Dissipation versus pressure drop | Fabian | Main CFD Forum | 1 | October 19, 2001 12:46 |
