September 3, 2009, 15:58 |
Difference between Ansys12 and fluent 6.3.26
vishwanath somashekar
Rep Power: 17 |
I am running the LES with same case file and with same parameters one on local machine with 8gb memory, intel quad core with ansys 12 installed, the other machine being a high performance cluster with 8gb shared memory with 4 processors per node, the processors are amd opteron 8378. I am seeing that the the case being run locally shows about 40 in the time/iter column, and the hpc one show about 2 mins. Is there a major difference between the two versions of fluent? Thanks, vishwa |
September 3, 2009, 16:02 |
#2 | |
Rep Power: 17 |
Also, I have pasted here at the output at the command prompt while the simulation is running. Like I have mentioned, I am running a LES simulation using NITA (PISO). My question is why is it that I see the continuity, x-velocity, y and z-velocity residual values for some time steps and not the others..
vishwa |
