3-D Water Flow in Fluent to Evaluate Pressures
Old   September 1, 2009, 16:16
Default 3-D Water Flow in Fluent to Evaluate Pressures
Allen Hammack
ahammack is on a distinguished road
I am trying to simulate a water flow, and there are some problems with the pressures and velocity magnitudes. I have one inflow boundary and one outflow boundary. All other surfaces have wall boundary conditions with a specified shear stress of zero in all directions. I am trying to get my reference pressures correct. Therefore, I am running no flow through the model (by specifying zero velocity through my inflow boundary), and the pressures in the flow domain should be hydrostatic. When I look at my results, I am getting velocity magnitudes up to 5 m/s and pressure that are hydrostatic but do not have the correct magnitudes for the given z-location. What can I check to find out what is wrong with my solution? Does my boundary condition setup sound wrong? Any ideas why the velocity magnitudes are so far from the prescribed inflow velocities? Are there any solver options/tolerances I need to be sure to check?
ahammack is offline   Reply With Quote
Old   September 1, 2009, 20:37
Chris
Chris D is on a distinguished road
Have you tried to change your "inflow" and "outflow" boundary conditions to "wall" so that you, essentially, have a tank filled with water (i.e., no flow)? Also, I think you need to turn gravity on if you want to solve a hydrostatic problem (it's off by default.)
Chris D is offline   Reply With Quote
Old   September 1, 2009, 23:41
Allen Hammack
Chris D,
Thanks for your reply! Yes, I have tried running a simulation with "wall" boundary conditions for all surfaces. I also have gravity turned on.
Another interesting thing I'm finding with my solution is that not only are the pressures not the hydrostatic values that I calculate analytically for the bottom of my flow domain (although I am getting a hydrostatic pressure distribution) the pressures are not constant for the same depths. This leads me to believe that the solver is not converging, but I can't seem to get any better solution behavior with the options I have changed so far.
Any suggestions?
3-d, fluent, pressure, water
3D-Simulation of Water Flow From Nozzle into Air Navin Sampath FLOW-3D 2 February 26, 2009 11:46
How to model suction flow in an airfoil in Fluent Davy FLUENT 4 October 23, 2006 04:56
Guage vs. Absolute pressures in Fluent. Riaan FLUENT 1 January 21, 2005 15:22
pressures in MDM - parallel fluent paolo FLUENT 1 April 7, 2004 01:38
How Fluent treat the pressure term in imcompressible flow Ray FLUENT 1 May 24, 2000 17:50
