Error: CDR: invalid argument [1]: wrong type [not a pair];Error Object: #f
Like Tree18Likes
Old   August 27, 2014, 09:16
Florin's Avatar
Florin Gheorghe
Florin is on a distinguished road
I had the same problem; it appeared after I have renamed a monitor I created earlier; after deleting the monitors this error disappeared.
Best regards,
Florin
Florin is offline   Reply With Quote
Old   November 11, 2014, 22:22
engilily
jsmloveu is on a distinguished road
OMG, it works when I restart! lol
thanks, Learner.
jsmloveu is offline   Reply With Quote
Old   April 8, 2015, 18:42
dirty trucker
jdwarren is on a distinguished road
Originally Posted by Tank View Post
I was receiving the same error message:
I solved this by deleting all my monitors. It also disappeared when I gave each monitor its own window.
So perhaps save your case and delete all your monitors to determine if this is the source of your problem?
Hope this helped!
I solved this problem the same way. However, I found that it was only two of my monitors which were causing the issue (I applied the process of elimination). I deleted and then redefined those monitors, after which the problem disappeared.
jdwarren is offline   Reply With Quote
Old   June 23, 2015, 02:07
Muhammad Imran Attari
2626imran is on a distinguished road
Originally Posted by caitoc View Post
Hi all,
I had this problem too during my fluent modelling in ansys workbench.
My solution is simple: reset the "Setup", open the fluent and now you should not encounter this error anymore
Thanks caitoc
I had the same problem and it works by resetting the solution setup
2626imran is offline   Reply With Quote
Old   October 25, 2015, 14:40
Default cdr: invalid argument [1]: wrong type [not a pair] Error object: #f
  #25
Seth Lawrence
slorenco is on a distinguished road
I recently encountered this problem while running fluent 15.0 and determined it was caused by my convergence monitors.
More specifically, the iterations to ignore appear to be have been the root cause; when set to ignore the first 500 iterations the solution always threw this error once the solution reached and attempted to exceed 500 iterations. Once the convergence monitors were removed, problem no longer persisted.
SOLUTION:
Remove/Replace convergence monitors (see iterations to ignore).
slorenco is offline   Reply With Quote
Old   March 16, 2016, 11:36
Filipe de Menezes
filipemt is on a distinguished road
Hope this helped!
Thanks Tank!
I just solved my problem as you said, deleting all monitors. A detail is that you can't delete residual monitors, but it is fine anyway.
filipemt is offline   Reply With Quote
Old   August 17, 2016, 18:27
AZ
mjthomp3 is on a distinguished road
Originally Posted by Perseu View Post
I have used the Fluent for simulation of wave generation in a tank (piston wave maker), but I have a problem when use a function "autosave". During the simulation, with many iterations (more 80.000), I saved the case and data through function autosave. However, when lack the electricity or when I cancel for a time and close the program for to begin again, occur the error:
Error Object: #f
Please, someone can help me?
Thanks
Perseu
i found the problem on my side. If you have zero for inlet BC, then you will get this error. I am using a journal file and set the velocities there, but thought i could leave the inlet BCs as zero. Nope.
mjthomp3 is offline   Reply With Quote
Old   October 31, 2016, 07:06
AHF
AHF's Avatar
amirhossein
AHF is on a distinguished road
i face to this error when i decided to active nist real gas.
any idea how to fix it ?
amirhosseinfardi94@gmail.com
AHF is offline   Reply With Quote
Old   January 16, 2017, 11:58
Sabomb
Sabomb is on a distinguished road
Just giving it a break seems to help. Try stopping the simulation, then restarting it after a while
Sabomb is offline   Reply With Quote
Old   July 4, 2019, 20:01
jonathas haniel
jonathashaniel is on a distinguished road
it is old but the solution is that some file isn't correctly loaded. Try refresh upstream components , or if you are trying to open the solution open and close first the setup before to fix the problem.
jonathashaniel is offline   Reply With Quote
Old   September 7, 2020, 11:55
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey everybody,
just want to confirm what Tank said. Removing my monitors and reports solved the problem. Interesting. However, I needed to load the data create from 20 R2 into 20 R1 as I need to export the data for ParaView and for some reasons the 20 R2 version does not work.
Probably there is a change in the file which needs to be incorporated into the ParaView reader first.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   July 7, 2021, 05:31
Lukas Fischer
lukasf is on a distinguished road
I also have not found a better way than to delete and create the reports again.
lukasf is offline   Reply With Quote
Old   July 7, 2021, 08:53
Tobi's Avatar
Tobias Holzmann
Fortunately I am going back to OpenFOAM. Fluent has some very interesting features I miss in FOAM but the GUI is so buggy in my personal opinion. It crashes several times each day.
Keep foaming,
Tobias Holzmann
Old   July 13, 2021, 07:02
杜家骏
djj11123 is on a distinguished road
I solved the problem based on the following situation: I opened the 2021 version of the fluent case with the 2020 version of fluent, and the error occurred, and the problem can be solved by recreating the case.
djj11123 is offline   Reply With Quote
Old   March 2, 2022, 05:50
Smile Removing monitors works!
  #35
Amal Roy
roym is on a distinguished road
Thanks @Tank. Same issue in my case is solved after removing all the monitors.
roym is offline   Reply With Quote
Old   December 1, 2022, 23:25
Smile For me it is the number of inconsistent inputs
  #36
Rui
roi247 is on a distinguished road
I am using scheme to write a journal file in fluent
(Do (( x 1 (+ x 1)))((> x 13))
(begin
(Ti-menu-load-string (format #f "file/transient-export/ascii plane~a pplane~a () x-velocity () yes no export-~a 1 time-step" x x x))
My command here tries to export 13 files "plane~a", on 13 different planes "pplane-~a", and name each of them "export-~a"...
I have got the same error
Error: CAR: invalid argument [1]: wrong type [not a pair]
Error Object: ()
I realized it when I was editing my Matlab file
e.g.
for i=1:100
name = sprintf('name-%d%d%d',i,i,i);
end
For the number of references in the command ~a of scheme, we have to input the same number of variables.
In my command I had 3 ~a
then I have to input three "x" for it to work.
roi247 is offline   Reply With Quote
Old   May 1, 2023, 10:37
Cooper Mao is on a distinguished road
Hi,I want to offer another solution method that might help.
Pls restart Fluent using DOUBLE precision option.
Cooper Mao is offline   Reply With Quote
cdr, error, fluent, invalid argument, wrong type
Error: CAR: invalid argument [1]: wrong type [not a pair]??? Paulus Fluent UDF and Scheme Programming 7 August 30, 2013 07:28
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
error: CDR: invalid argument [1]: wrong type Marc FLUENT 0 July 24, 2006 06:59
