MK
Rep Power: 17 ![]() |
Hi everybody.
Who knows how I can define the best heat transfer boundary condition for a surface between two zones, for example solid/fluid or solid/solid? I have already generated the geometry and mesh file of two zones, but I can't apply B.C. to the interface wall. thnx |
wu
You can add something to the interface boundary (fluid/solid).
There you can define a "heat generation rate" boundary. I think, you can use UDF to define this value, if it is not constant. |
MK
I want to simulate a geometry like this:
T_o --------- solid --------- Fluid --------- T_i |
conduction, conjugate heat transfer, zones |
Slip flow boundary condition on wall using UDFs | mahdi haddad | FLUENT | 1 | November 11, 2014 06:13 |
How to set rotating wall as boundary condition | babu | FLUENT | 7 | December 14, 2013 04:48 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
