k-omega turbulence model: 1 vs 2 order solution |
August 31, 2009, 15:57 |
Silvia
Rep Power: 17 |
I am modelling film cooling on a blade leading edge. I got a good solution with ke realizable turbulence model. Then I refined the grid so that y+ is less than 5 and I set the kw SST turbulence model. I can get convergence only with the first order scheme solution in the dissipation rate. When I shift to the second order solution, omega residuals jump and suffer for high oscillation. Do you have any suggestion to fix the problem? Thans in advance Good work to everybody Silvia |
Getting steady-state solution for turbulent model? | Kwontona | FLUENT | 0 | February 23, 2007 18:14 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 07:12 |
Turbulence model equations | Vidya Raja | FLUENT | 1 | September 18, 2006 01:09 |
HELP!! Prandtl numbers in RNG k-e turbulence model | maoasis | FLUENT | 0 | April 24, 2006 11:51 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
