Problems with gambit mesh
Old   August 28, 2009, 09:59
Default Problems with gambit mesh
Emanuele Leoni
lions85 is on a distinguished road
I need your help with gambit because i'm not able to create a right mesh.
I start from the beginning.
I'm a beginner using fluent and gambit too. I need to create a mesh that is a section of a burner, so the grid has to be a kind of rectangular and meshed gradually. The grid is a 2D grid because then in fluent i'll use the axialsimmetric property and in this way i'll be able to process the simulation.
I created the mesh in this way. First i created the points, then I created the edges and finally I created the plane inside the edges. Then i meshed the edges and then i meshed the inside part. I think it is all right.
Then I exported my mesh in *.MSH format and then I tried to read the case with fluent.
The problem is that if I open a 2d section of fluent, i get this message:
"Error: File has wrong dimensions (3).
Error Object: #f"
If I start the 3d section the result is:
" Reading "C:\Users\lions\Desktop\PROVA2.msh"...
55 nodes.
40 mixed wall faces, zone 2.
Error: no cells in zone, id = 0, ind1 = 1, indn = 0Reading Cells: failed while reading section 12.
Clearing partially read grid.
Error: Read aborted due to critical error.
Error Object: () "
I think the problem is that I have to declare that the mesh is a 2d mesh, but I don't know how to make it.
Could someone help me please?
Thank you very much
Emanuele
lions85 is offline   Reply With Quote
Old   August 28, 2009, 13:44
Troy Snyder
tas38 is on a distinguished road
When exporting the mesh, in the dialog box to specify file name, there is a check box that must be activated to flag the mesh as 2d.
Export 2-D (X-Y) Mesh
This may solve your problem.
tas38 is offline   Reply With Quote
Old   August 28, 2009, 20:05
Emanuele Leoni
Yes, it works. It was so simple.....
thank you very very very much, now i can start with the simulations.
Emanuele
Gambit - Mesh Problem for a complex 3D geometry Nelson FLUENT 3 May 28, 2012 07:57
Successive Mesh in Gambit ashish FLUENT 0 April 28, 2006 01:42
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 02:04
error when mesh in Gambit icestar FLUENT 2 October 28, 2004 15:11
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 04:10
