udf for adsorption coefficient
Old   August 19, 2009, 16:10
Question udf for adsorption coefficient
beibei
bzhu is on a distinguished road
I need to define my own adsorption coefficient of solid quartz as a function of x due to some chemical change. Shall I define it as a thread or cell or something else? This is my first time to use udf ever and C program since 15 years ago. Could you gurus check my code for me? thanks! Here's my C code:
UDF for specifying a x-axis-dependent absorption property
#include "udf.h"
DEFINE_PROPERTY(absorption_coefficient, thread, index)
real abs_lam;
real x;
if (0 < x < 0.2)
abs_lam = 0.1111;
else if (0.2 < x < 0.4)
abs_lam = 0.2222;
else if (0.4 < x < 0.6)
abs_lam = 0.3333;
else if (0.6 < x < 0.8)
abs_lam = 0.4444;
else
abs_lam = 0.5555;
return abs_lam;
bzhu is offline   Reply With Quote
Old   August 20, 2009, 03:48
Max
coglione is on a distinguished road
Hello Beibei,
1) if x should hold the position in x-direction of a given cell you must retrieve the coordinates of its centroid by using the macro C_CENTROID(pos,c,t) where pos is a vector with components (x,y,z). To get x use pos[0].
2) the correct syntax for DEFINE_PROPERTY is DEFINE_PROPERTY(name,c,t), no index in it!
Have a look at the udf-manuel, surely there is an example which is close to your specific application.
cheers
coglione is offline   Reply With Quote
Old   August 24, 2009, 16:09
beibei
Thank you for help! I revised my code as:
#include"udf.h"
DEFINE_PROPERTY(absorption_coefficient, c, t)
real abs_coeff;
real pos;
C_CENTROID(pos[0],c,t);
if (0 <= pos[0] < 0.2)
abs_coeff = 0.1111;
elseif (0.2 <= pos[0] < 0.4)
abs_coeff = 0.2222;
elseif (0.4 <= pos[0] < 0.6)
abs_coeff = 0.3333;
elseif (0.6 <= pos[0] < 0.8)
abs_coeff = 0.4444;
else
abs_coeff = 0.5555;
return abs_coeff;
But it still didn't work. FLUENT gave me the error message of "line9: subscription expression is not an array or pointer: float". This pointer stuff is killing me. I never really understand the concept.
Could someone help me? Thanks a lot!
Old   August 25, 2009, 04:53
Max
beibei, that's really basic C-stuff which you should try to understand as soon as possible if you need to use udf's.
However, as already stated pos is a vector, so you need to deslare it as one:
real pos[ND_ND]; (ND_ND is a fluent macro returning the right dimension automatically for 2d/3D)
then get the Cell-Center_coordinates into it:
C_CENTROID(pos,c,t);
The rest should be o.k.
cheers
Old   August 26, 2009, 14:14
beibei
Thanks! I revised my code as:
#include"udf.h"
real abs_coeff;
real x[ND_ND];
C_CENTROID(x,c,t);
if (0 <= x[0] < 0.2)
abs_coeff = 0.1111;
elseif (0.2 <= x[1] < 0.4)
abs_coeff = 0.2222;
elseif (0.4 <= x[2] < 0.6)
abs_coeff = 0.3333;
elseif (0.6 <= x[4] < 0.8)
abs_coeff = 0.4444;
else
abs_coeff = 0.5555;
return abs_coeff;
It could interprete to FLUENT. The problem is that after iteration, I checked the adsorption coefficient. It didn't look like a function of x position. Could you see the cause in my code? Thanks!
Old   August 27, 2009, 05:41
Max
yes i see the reason and you should be able to find the error too. I guess you do not really intend to solve a 5-D problem which would at least give some physical meaning to x[4] !
cheers
Old   September 17, 2009, 11:36
beibei
I revised my code as below and FLUENT didn't seem to render it even though it could interprete. I changed the x-position dependent to a constant jsut by replacing the if-command to a constant to see if fluent can exert, and it didn't. What could it be wrong? Couldn't fluent render udf on a surface? Please help! Thanks!
Here's my code:
#include"udf.h"
real abs_coeff;
real x[ND_ND];
C_CENTROID(x,c,t);
if (x[0] > 0 && x[0] < 0.2)
abs_coeff = 593.9187;
elseif (x[0] > 0 && x[0] < 0.2)
abs_coeff = 197.6521;
abs_coeff = 177.0521;
abs_coeff = 140.5854;
else
Message(
"Abs coefficient for this cell %e = %e", x[0],abs_coeff);
return abs_coeff;
adsorption coefficient, code, fluent, udf
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 09:43
how to define restituition coefficient using UDF? haijj FLUENT 6 July 10, 2008 00:26
UDF for Heat transfer coefficient Dong Wenchao FLUENT 2 August 23, 2006 07:35
heat transfer coefficient udf nam su FLUENT 0 March 25, 2005 03:28
UDF - Heat transfer coefficient kulasekharan FLUENT 3 August 12, 2004 08:09
