Convergence criteria of Solid liquid two phase flow.
Old   August 17, 2009, 18:48
Default Convergence criteria of Solid liquid two phase flow.
Gaurav
trystwithgaurav is on a distinguished road
I am trying to model the flow of calcium carbonate particles in water through a pipe with diameter 0.1016m with the velocity of particles as 0.5m/s and that of water as 0.78m/sec. I am using the mixture model. I am running the simulations with the convergence criteria of residuals at 1e-5 but the continuity and the Z-velocity doesnt seems to be converging at all even after something around 11100 iterations. They still fluctuate at around 1e-2.
Can anybody guide me for how to achieve my solution to converge? If under relaxation factors are the deciding ones, what should be the values i should actually use?
Thanks
Gaurav
trystwithgaurav is offline   Reply With Quote
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
2 phase flow liquid flow solid particles sachin OpenFOAM Running, Solving & CFD 0 August 28, 2008 17:51
Convergence for inviscid flow over sylinder Rjakk Main CFD Forum 2 March 21, 2007 11:53
Gas Liquid flow in a packed column Rakib FLUENT 8 June 18, 2002 02:58
Combusting Two Phase Flow Abhijit Tilak Main CFD Forum 1 January 25, 1999 10:43
