how to add heat source with constant temp and heat generation rate
Old   August 17, 2009, 14:06
Default how to add heat source with constant temp and heat generation rate
Leila Dominguez
leila is on a distinguished road
Hi!
I'm quite a new Fluent user and I'm in the learning phase. I hope you can help me out. I am modelling a production room and I need to put in a heat source (pig, actually) which is of constant temperature and generates heat at a constant rate. How can I specify that in Fluent?
Thank you very much.
Leila
leila is offline   Reply With Quote
Old   August 19, 2009, 01:55
Narayansing
chhanwal is on a distinguished road
You have to give constant temperature in the boundary condition for the volumes. there are three options one is Fixed values in which you can give constant temperature value or in second option for source term where you can give heat generation rate.
chhanwal is offline   Reply With Quote
constant temp, fluent, heat source
solid heat source ocy FLUENT 3 February 22, 2005 23:58
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 13:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 14, 2000 00:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
