August 13, 2009, 14:26 |
UDF for turbulent flow
Binu B Tharayil
Rep Power: 17 |
Hi....
Can anyone help in writing a udf for specifying velocity profile for turbulent flow....? I wrote one and saved as a plain text with extension *.c. It builds while running in fluent, but when trying to load, A message comes like, Error: open_udf_library: No such file or directory. Any help is appreciated in advance... Regards... |
August 13, 2009, 19:07 |
Rep Power: 17 |
Fluent has an example for a parabolic velocity inlet - have you looked at that? Sounds like you would just need to follow that exactly, with the exception that you'd change the equation for the velocity profile.
August 13, 2009, 19:08 |
Rep Power: 17 |
Also, Fluent stores a log file in the directory where you're compiling your UDF (if you're using it as a compiled UDF.) Check that file for a description of the problem Fluent ran into loading the library.
UDF of two phase flow : drag coefficient | superxeonman | FLUENT | 0 | May 21, 2008 22:53 |
Help slip flow UDF | Tajul | FLUENT | 2 | December 20, 2005 07:17 |
How to define mass flow rate using UDF? | SAMUEL | FLUENT | 3 | December 25, 2004 01:36 |
How to define mass flow rate using UDF? | SAMUEL | FLUENT | 0 | December 16, 2004 03:55 |
UDF for multiphase flow | ROOZBEH | FLUENT | 3 | April 7, 2004 18:54 |
