August 7, 2009, 05:41 |
Study of a Rear wing
Maxime
Rep Power: 17 |
Hi every body!
I'am doing a study of a rear wing for a sportcar and I have some problems. Indeed, I have somme difficulties to find the right boundaries conditions I put Velocity-inlet where the fluid is coming and where the fluid gets out I put Pressure outlet but i have "reversed flow" and i don't know how to fix that... Thank you Max |
August 7, 2009, 18:50 |
solution
Carl
Rep Power: 17 |
Move your outlet further away from the wing, it must be in the re-circulation zone in the wake so it needs to be at least 10x away from the wing, where x=car length.
Also, the wing should be modelled with the vehicle, they dont work in isolation because the angle of attack is too high - they only work in conjunction with the upwash generated by diffusers. |
August 10, 2009, 04:45 |
Maxime
Rep Power: 17 |
Ok I'll try that! Thank you!
Forward swept wing simulation | abid | Siemens | 1 | June 16, 2012 14:26 |
Cp values for F3 rear wing for a 4th year thesis | Joe Bryant | FLUENT | 4 | June 11, 2010 00:40 |
Wing Study Cases | albertolot | Main CFD Forum | 3 | August 10, 2009 11:28 |
3D wing study | Bridou | FLUENT | 5 | July 22, 2007 20:03 |
2D wing study | antoine | FLUENT | 1 | January 27, 2005 10:56 |
