[Validation: marine] Hydrofoil NACA 0024
Old   July 28, 2009, 09:41
Default [Validation: marine] Hydrofoil NACA 0024
axpl's Avatar
Alexandro Palmieri
axpl is on a distinguished road
Send a message via Skype™ to axpl
I'm starting my thesis in marine CFD and I need to validate Fluent code with Hydrofoil NACA 0024 with this exp data.
Here (pdf file) I found a tutorial to setup the problem, unfortunatly I haven't found mesh file so I done it by myself: my domain is a box with NACA at center (it's a full model, I haven't use symmetry). BC are: p-inlet-upstream, p-inlet-side-1, p-inlet-side2, p-outlet-exit, sym-bottom, sym-top, wall-wing.
I following the tutorial but I see only one phase.
Can someone help me to setup this problem correctly?
Syncerely, Alex.
axpl is offline   Reply With Quote
Old   July 28, 2009, 10:47
Dimitrios Mylonas
Dimo is on a distinguished road
there should be two phases, as defined in pages 3 & 4 of the tutorial. primary phase: air, secondary phase: water
Dimo is offline   Reply With Quote
Old   August 6, 2009, 06:45
Default .CAS file
axpl's Avatar
Alexandro Palmieri
If you want check my run, here I post *.cas file (approx 60MB). Actually I can't yet understand where is my error but I suppose in boundary condition.
Sincerely, Alex
PS: someone can tell me where can I found "sp_naca0024_hf.msh" file? So I can compare BC with mine.
Old   September 19, 2009, 10:18
Default UDF: unsteady inlet velocity error...
axpl's Avatar
Alexandro Palmieri
Solving my last problem patching all the water volume (see first post), now I'm setting an unsteady run but after 10 time step (0.005 sec each) I receive an alert of reverse flow on inlet, but only when I try to create a ramp velocity inlet via UDF; if I set a costant initial condition I never receive error. Someone can HELP me?
File Type: c velocity-inlet.c (568 Bytes, 31 views)
marine, validation, vof
