Mixing Tank One Way FSI
Old   July 26, 2009, 14:38
Default Mixing Tank One Way FSI
Claudio
Claudio2010 is on a distinguished road
I'm a structural engineering student and I have the following problem: I modelled a cylindrical tank with two impellers that rotate at 19 rpm with a k-epsilon turbulence model in Fluent. The flow generates a pressure on the cylinder wall and baffles; that's what I'm interested in. Fluent gives me various pressure values: static pressure, dynamic pressure, total pressure, absolute pressure and relative absolute pressure. Which of this values represents the total loading on the cylinder wall and baffles? I mean, if I structural engineer wanted to design the cylinder wall, which of these values should he use? I couldn't figure it out.
Also, I thought static + dynamic pressure = total pressure. However, looking at the results they don't sum up. Why could that be?
Finally, I'm a little confused about what static pressure really means.
I would appreciatte greatly any help!
Thank you!
Claudio2010 is offline   Reply With Quote
Sliding mesh setup for a mixing tank in Gambit nycera FLUENT 13 October 11, 2016 15:39
Mixing Tank bimlesh kumar FLUENT 3 July 6, 2013 18:14
Modelling mixing tank using MRF Adi FLUENT 6 November 4, 2009 01:28
help about modeling A MIXING TANK hmasenger CFX 2 April 13, 2009 16:21
MixSim to Gambit (Mixing Tank) Eric R. FLUENT 2 April 17, 2002 10:35
