Meshing Volume in Gambit for a water turbine
Old   July 23, 2009, 17:07
Default Meshing Volume in Gambit for a water turbine
Zaqie
Zaqie is on a distinguished road
I am doing a fluent analysis on a water turbine. I have created the geometry for the turbine in Rhinoceros.
I have meshed the the faces of the turbine in Gambit. Also, I have meshed the faces of the fluid domain(which is a cylinder encompassing the turbine. Now when I try to mesh the volume(i.e the volume of turbine subtracted from the volume of cylinder), I get the following error:
" Meshing of the volume has been aborted due to poor face quality mesh. The user may proceed by first remeshing the faces with poor mesh quality or attempt to mesh the volume with existing face meshes"
While meshing the faces I have taken care not to exceed equisize skew for any element (adjusted the value to 0.98) and all the faces where successfully meshed. But interval sizes are varied for the faces. Could it be a problem?
Expecting an earliest reply.
Thanks
Zaqie
Zaqie is offline   Reply With Quote
Old   July 24, 2009, 02:25
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Check where is the problem with your surface mesh.
Correct it and mesh the volume
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
gambit, mesh quality, turbine
Water turbine CFD modeling Peter Main CFD Forum 7 April 4, 2016 03:31
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
? Meshing volum in GAMBIT enemi09 FLUENT 0 March 7, 2005 04:23
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 12:08
