July 20, 2009, 18:10 |
Air Lift Pump BCs
Ramesh
Hi All,
I am simulating flow through an air lift pump using fluent, validating with experimental data that gives me maximum efficiency (Mw/Ma). Air is being injected radially from the bottom of the pipe and water is being sucked from bottom. I tried mixture model with k-e turbulence model. The inlet velocity of air 10 m/sec with volume fraction of 1.I assumed the bubble diameter is radial hole diameter. When I solve it, the mass flow rate of water is coming as zero. This may be due to there is no inflow of water. Can anybody suggest me better boundary conditions.I am attaching brief description. Thanks, Ramesh Gannamani. |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
air pump calculations??? | VVJ | Main CFD Forum | 0 | February 12, 2008 14:13 |
Airfoils and lift compared to air density and TE | Jens | Main CFD Forum | 0 | May 4, 2006 04:31 |
PUMP air into the container | PIN TU | Siemens | 1 | July 21, 2004 10:48 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
