Export results into txt
Old   July 16, 2009, 15:18
Default Export results into txt
Acoidan Betancort Mondesdeoca
AcoidanBM is on a distinguished road
Hi there,
I'm to export all the results of my study to a database (MySQL). To do that, I copy the fluent forces report to a txt file, then modify it to read it from the mysql server. But I wonder if it is posible to obtain the data in other way. I mean, I don't know if I can export the forces report to a txt file with another format, for example, all the data in a line separated by tabs.
Can you help me?
Thank you very much
Acoidan
AcoidanBM is offline   Reply With Quote
Old   July 17, 2009, 12:58
Akour
ak6g08 is on a distinguished road
hi,
there are various formats available for you to export data in, if you go file, export (i think), you can choose the variable to export and save it as a specific file type, this can be done automatically as well,
an comma separated ascii file would be exported as:
x y z variable1 variable2 variable3 etc...
you can tell fluent to export a data file every X number of iterations or timesteps...this is all in the manual, search for data export...
akour
ak6g08 is offline   Reply With Quote
Old   July 24, 2009, 16:00
Thanks a lot, but I can't save the forces report by exporting it as you said. Finally I decided to make an Matlab program to modify the results and to copy them into a SQL database.
Now I'm trying to connect matlab to the MySQL server.
Thank you very much.
how to export every data w.r.t time to txt file jaho CFX 94 August 25, 2015 10:45
export results for tecplot from CFX-Post iperten CFX 3 July 11, 2009 09:11
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Export CFD Solver results to text file format Maik Main CFD Forum 2 May 23, 2008 02:34
Export symmetric results Mahdi FLUENT 0 May 4, 2005 08:05
