Strange lift coefficients for NACA 0012
Old   July 15, 2009, 10:06
Default Strange lift coefficients for NACA 0012
Dan
dss1092 is on a distinguished road
I'm running some tests on a NACA 0012 airfoil with Re = 9e6 and I've been getting some strange values for the lift coefficient. For a 4 degree angle of attack, I'm getting a lift coefficient of 0.1, which is far too low. For zero angle of attack, I'm getting 0.007. I'm using a velocity inlet and the outflow bc for the outlet. I've tried using equivalent pressure boundary conditions and got very similar results. I also check the reference values and I think they're ok. The velocity reference is set to the inlet velocity, and the area is the length of the airfoil. Any thoughts as to why my results are not good would be greatly appreciated. Thanks!
dss1092 is offline   Reply With Quote
Old   July 20, 2009, 11:49
Joaquin
jortega is on a distinguished road
I am working with the naca0012 airfoil, too. I am doing some preliminary simulations with an angle of attack of 9 degree and Re=50000 and the Cl and Cd seems rights.
Are you using a turbulent model?
jortega is offline   Reply With Quote
Old   August 27, 2009, 12:02
nvtrieu is on a distinguished road
Hi all,
I'm simulating NACA 0012 too (chord =4m) in Star-CCM+. I use turbulent model like K-ep and K-w. The fuid is H2O. Velocity =1~10 m/s. Attack angle =2~16deg. I got the incorrect lift coef. and drag coef. because the lift coef. is so small.
Who have experience on this problem please help me!
Thanks alot!
nvtrieu is offline   Reply With Quote
fluent, lift coefficient
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
how to set lift and drag coefficients in force mon alagesanj FLUENT 0 November 16, 2008 21:47
Lift and Drga coefficients for an airfoil Kevin CFX 4 November 2, 2006 16:48
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
pressure. lift and drag coefficients waqar mahboob Main CFD Forum 0 July 25, 1998 04:34
