initialize flow field with steady state solution |
July 13, 2009, 18:10 |
holger thiele
hi, I want to calculate the heat flux into a flat plate of a turbulent airflow over this plate with a transient solution using realizable k-e-model. My problem is I don't get convergence for the continuity equation. So my idea now is to take the solution of the continuity and turbulence equations I obtained from a steady state simulation and use these as constant values for the transient solution of the energy equation because the flow field is independent of the temperature profile but the temperature profile is dependent on the flow field. so my question is how can I initialize the flow field with this former steady state solution? I use constant properties for air and a rectangular mesh. thanks in advance
Steady State 2 phase problem | fivos | FLUENT | 0 | April 27, 2009 17:34 |
Problem: text commands to initialize flow field | Carolyn Jacobs | FLUENT | 0 | April 10, 2007 06:03 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
External flow field. | Moon | FLUENT | 3 | March 5, 2003 11:32 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 15:37 |
