July 13, 2009, 06:46 |
FLUENT Journal File Errors
Rep Power: 17 |
I'm running a series of FLUENT journal files from MATLAB. Assuming the journal commands are in the form: file/read-case-data myshape.cas solve/iterate 10000 file/write-case-data y exit For certain shapes FLUENT does not converge due to an ill-defined geometry / solver conditions and an error is displayed in the form: Warning: An error or interrupt occurred while reading the journal file. Some commands may not have been completed. In this case FLUENT becomes 'idle' at the error. Ideally, I need the program to exit when an errors appears. Can you please suggest how I can force FLUENT to exit for such cases / or alternate strategies to handle journal file errors? Thanks |
July 9, 2010, 05:08 |
Hi cfd23,
Did you get any answer on this, or find an alternate solution? I am myself running series of batch calculations and it is always irritating to find out after a computation night that the second run crashed... I would like to just skip faulty calculations and continue with the batch run but prove unable to handle fluent errors... Thank you in advance for any hint... calemarie |
July 9, 2010, 05:19 |
Rep Power: 17 |
Hi Mate,
Thankfully, FLUENT has a built in option for such cases. Under batch options, there is an 'exit on error' option which you need to check. It does what it says: When and if FLUENT hits an error, the program exits and your calculations will continue to run. I use MATLAB to launch all my jobs, so I simply enter a user-defined magnitude for failed simulations so that I know where the problem occured. See how you go! |
July 14, 2010, 05:12 |
novice
Rep Power: 17 |
Hi CFD23,
Its interesting to know that a Fluent process can be launched through MATLAB. Can you pls send me an example file to launch the FLUENT through MATLAB. Thanks in advance |
How to comment a Fluent journal file | Bottenheim | FLUENT | 11 | December 16, 2024 10:54 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 11:23 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 17:31 |
Fluent File Size | John S. | FLUENT | 2 | February 3, 2009 11:20 |
strange error with journal file | Ralf Schmidt | FLUENT | 0 | March 15, 2006 11:47 |
