UDF for reading dat files
Old   July 8, 2009, 10:10
Default UDF for reading dat files
mrestrepo30 is on a distinguished road
I wrote a UDF to read some velocity values from a .dat file, and the values are represented in 3 columns for each one of the XYZ components. In the UDF I'm using standard C functions (fopen, fscanf, etc).
When I execute the UDF (on demand) in Fluent, I can read up to the row number 1169 (out of 3800); however, when I get to the line 1170, I get the following message:
/home/local/Fluent.Inc/fluent6.3.26/lnamd64/3d/fluent.6.3.26[0xdd6fcb]
/homPlease include this information with any bug report you file on this issue!
/home/local/Fluent.Inc/fluent6.3.26/bin/fluent: line 4820: 4012 Segmentation fault $NO_RUN $EXE_CMD $CX_FLAGS
e/local/Fluent.Inc/fluent6.3.26/lnamd64/3d/fluent.6.3.26[0xdd6f21]
/lib64/tls/libpthread.so.0[0x3d2df0c4f0]
libudf/lnamd64/3d/libudf.so(read_vel+0xbd)[0x2a962a85c1]
The fluent process could not be started.
Furthermore, in the line 1130 I get always the message:
Stack backtrace generated for process id 4012 on signal 1 :
Does anyone knows why I keep getting the error and maybe has any suggestion to what should I implement in order to avoid this and read the whole *.dat file???
Thanks!!!
mrestrepo30 is offline   Reply With Quote
dat, fscanf, read file, stack backtrace, udf
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
UDF for reading dat files mrestrepo30 Fluent UDF and Scheme Programming 2 July 9, 2009 17:47
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 11:46
Associating profile files for the UDS though a UDF Bharath FLUENT 0 December 1, 2006 16:58
[making animations] fclose fails to close files? Mika FLUENT 0 March 30, 2001 09:19
