sliding mesh, confused me, help! help!
Old   July 8, 2009, 04:33
Default sliding mesh, confused me, help! help!
Wei Yang
weiyang1980 is on a distinguished road
Send a message via MSN to weiyang1980
Hi,all:
In CFD simulation for an airfoil, we usually give a velicoty in let and let the airfoil static.
Now, I am doing a cfd simulation that let the air stable, the airfoil slids in a box. Yes, dynamic mesh method can do it. But I want to resolve it by using the sliding mesh method, for there are some articles describing studies for car and train in crossing action.
When I set up the sliding mesh and run FLUENT, I found the box at which the airfoil is has a velocity specified for the airfoil wholly. While what I want is the airfoil has a velocity and moves forwards, the air around is static. Does the velocity of sliding mesh mean the velocity of each fluid element in that mesh? In another word, if one part of mesh is sliding at velocity V, is the fluid in that mesh also moving at velocity V?
thanks!
weiyang1980 is offline   Reply With Quote
Old   September 22, 2009, 22:14
Wei Yang
I have found the key.
A stable result is need before carry sliding mesh simulation.
And yes, the stable initialization means the whole flow holds a velocity of zero. Then let the sliding mesh work. It does work.
The result brings some other question. The lift and the drag is not good,there is some difference from results of conventional CFD study.
Wei Yang Ph.D. student Shanghai Automotive Wind Tunnel Center Tongji University Shanghai 201804 P.R. China
Old   September 30, 2009, 22:45
herntan's Avatar
YH Tan
herntan is on a distinguished road
Your simulation on sliding mesh is interesting.
I guess ur using the air above and below the airfoil to slide and have the mesh periodic. am i right?
Can you share some of ur picture of simulation?
u said there is differences with conventional CFD study, what is the difference?
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Sliding mesh error alice FLUENT 3 February 21, 2012 06:53
sliding moving mesh with STAR-CD 4.06 ELYOR Siemens 1 June 30, 2008 09:54
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Location of interface for sliding mesh Gopal FLUENT 1 July 14, 2005 05:30
